Forcing Lowercase in TextExpander output
Mr.Aky
Post by Mr.Aky » Sep 2nd, ’21, 06:45
Usually if a text is written in lower case is expanded in lowercase,
if it is written in UPPERCASE is expanded in UPPERCASE.
Is it possible to expand always in lowercase ?
Post by Tom » Sep 2nd, ’21, 20:40
You can disable the "Adjust to typed case" option in Preferences/Text Expander.
Mr.Aky
Post by Mr.Aky » Sep 3rd, ’21, 05:43
Thank you
