Custom size/Resize radio button form
jvroom
Post by jvroom » Aug 14th, ’21, 17:11
Hi All.
When creating/using a Selection Form >> Selection form type = Radio button...
Question: Is there a way to resize (initial form display size) a radio button form? Some of the radio button options (the options text label/description are long and are cut off on the auto-generated form).
Let me know.
Post by Tom » Aug 14th, ’21, 17:21
You can resize a selection form width in Preferences/Text Expander/Advanced.
