Start Menu (Menu 1) Move [Recent|Clipboard| Settings]?
jvroom
Post by jvroom » Jul 13th, ’21, 15:14
Good day All,
Question...
Is there a way to move the following Start Menu (Menu 1) items?...
Recent
Clipboard
Settings
The above items are included at the bottom of Start Menu 1, but I don't see these items listed on the configuration page where you can select menu items and add/delete/move them.
If possible I'd like to be able to relocate the items closer to the top of the menu list. They're currently (automatically/by default?) positioned at the end of the menu.
Post by Tom » Jul 14th, ’21, 16:56
Recent items are shown on the top of the menu, Clipboard and Settings at the bottom. You can remove any of them in Preferences/Start Menu.
