'Countdown Timer Big' but for minutes
Oblomov
Post by Oblomov » Jun 23rd, ’21, 11:03
I wanted to change 'Countdown Timer Big' to minutes only, where I changed 'secsLeft' to 'minLeft':
if WinExist("MyCountdown") {
 Gui, 19:Destroy
 SetTimer, ShowTimerCD, Off
else {
InputBox, minLeft , Countdown, Countdown Minutes:,,160,123,,,,15
If ErrorLevel
 Return
Gui 19:+LastFound +AlwaysOnTop -Caption +ToolWindow
Gui 19:Color, EEAA99
Gui 19:Font, s228
Gui 19:Margin, 0, 0
Gui 19:Add, Text, w335 h290 yp-50 Vdisp Cred Right
WinSet TransColor, EEAA99
Gui 19:Show, NoActivate, MyCountdown
SetTimer, ShowTimerCD, 1000
Gosub ShowTimerCD
Return
ShowTimerCD:
minLeft--
IfEqual, minLeft, 0
  Loop 4
  GuiControl, 19:Text, disp, 0
  Sleep 400
  Sleep 400
  SetTimer ShowTimerCD, Off
  ;Sleep 3000
  Gui, 19:Destroy
Else
  GuiControl, 19:Text, disp, %minLeft%
Return
But when I enter '1' into the input field now, I only get some red numbers flashing by 😞
Perhaps someone could point me in the right direction?
Post by Tom » Jun 24th, ’21, 11:11
The original script changes the count each second using a timer. The only thing you would need is to change the time from one second to 60 seconds:
SetTimer, ShowTimerCD, 60000
Oblomov
Post by Oblomov » Jun 24th, ’21, 11:58
Tom wrote: Jun 24th, ’21, 11:11 The original script changes the count each second using a timer. The only thing you would need is to change the time from one second to 60 seconds:
Awesome, thanks!
