Activating a keyboard shortcut
dlccarlson
Post by dlccarlson » Jun 20th, ’21, 23:23
Hello, I am trying to create an action so when I type sss the software will press the keys (windows key + shift + s) but I can't figure out how to do this. Thanks for any help you can give me.
Post by Marko » Jun 21st, ’21, 15:36
Few alternatives
Type: Send
{Win Down}{Shift Down}S{Win Up}{Shift Up}
or if the Enable modifiers option is enabled in Preferences/Text Expander
#+s
Type Command:
Send, #+s
