Tilde after command execution
Oblomov
Post by Oblomov » Jun 16th, ’21, 17:34
Not sure if this is more of an AHK-related problem, but I couldn't find much through searching...
Basically when I press 'CTRL + ALT + TREMA' (TREMA = ¨), to execute a command, it always adds a '~' in the beginning, whenever I start typing. Is there any way to prevent this perhaps?
Kind regards,
Post by Marko » Jun 16th, ’21, 18:52
I believe this is a Windows Keyboard setting, try it without FastKeys running.
Oblomov
Post by Oblomov » Jun 16th, ’21, 19:04
Marko wrote: Jun 16th, ’21, 18:52 I believe this is a Windows Keyboard setting, try it without FastKeys running.
Indeed... was just wondering whether there was some way of preventing this perhaps 🤔
