Search Start Menu button text?
jvroom
Post by jvroom » Jun 16th, ’21, 13:00
Hi All,
If you have a large Start Menu that contains a lot of buttons with buttons that also incode button descriptive text like this amazing Start menu...
viewtopic.php?f=4&t=1516
...can anyone think of a way for a text search to be run over all the Start Menu button text? Goal: Search all the Start Menu buttons text for the search keyword and have FastKeys highlight the searched for words throughout Start Menu's button's text. (Hopefully, I've described thing clearly)
Post by Marko » Jun 16th, ’21, 18:49
Unfortunately there is no such option.
But you can always use a Quick Find window for searching - check it out.
