Pop Up Screen
diddie
Post by diddie » Jun 10th, ’21, 02:48
Hi guys,
I have 2 monitors, but my wordlist everytime appear in a incovinient part of the screen
Exist an ahk code tu configure my wordlist in a specific parte of the screen?
P.S I tried all configurations, above the caret, tray, mouse cursor, but it is incovinient. Mouse cursor is good, but sometimes I have to see monitor 1 and other time monitor 2, so boring
Post by Tom » Jun 10th, ’21, 10:06
In normal applications, using “Below the caret” setting should be the one to use. In browsers, the caret position cannot be determined (system limitation) therefore you are able to set the alternative position. Have you tried “Centered”?
