Selection Form with Multiple Line
vincentt
Post by vincentt » May 19th, ’21, 16:10
Hi Fastkeyer,
First of all, thank you the developer create a great software for us.
Is it possible to add multiple lines by checkbox?
For example,
Bank Name 1::Bank Address
Bank Account No.
Bank Contact No.
Bank Name 2::Bank Address
Bank Account No.
Bank Contact No.
I know I can use auto complete to make the same outcome such as set the string to Bank and Bank*. If the method above work, I believe it's more clean.
Post by Tom » May 19th, ’21, 20:51
Sure, you can use a ¶ character or {Enter} for a new line.
Bank Name 1::Bank Address{Enter}Bank Account No.{Enter}Bank Contact No.
Bank Name 2::Bank Address¶Bank Account No.¶Bank Contact No.
vincentt
Post by vincentt » May 20th, ’21, 02:31
Thanks for your quick reply! This is helpful.
Last question, can set multiple strings at once for auto complete? Or it's only available for text expander.
For example:
bank/bkname
Cheers
vincentt
Post by vincentt » May 20th, ’21, 09:51
I found out my solution by using text expander with separator.
I'm happy with my purchase.
Thank you so much!
Cheers
Post by Marko » May 21st, ’21, 13:32
vincentt wrote: May 20th, ’21, 02:31 Last question, can set multiple strings at once for auto complete? Or it's only available for text expander.
You can set the string with multiple words and enable "Include words containing the string" option.
vincentt
Post by vincentt » May 21st, ’21, 15:52
Marko wrote: May 21st, ’21, 13:32 You can set the string with multiple words and enable "Include words containing the string" option.
Wow, it's what I need. I think FastKeys has a lot hidden features really helpful!
