does fastkeys have a silent install option?
I would like to add it to chocolatey
silent install
The following optional command line parameters can be used with the provided FastKeys installer:
/SP - Disables the This will install... Do you wish to continue? prompt at the beginning of Setup.
/SILENT - Instructs Setup to be silent. When Setup is silent the wizard and the background window are not displayed but the installation progress window is.
/VERYSILENT - Instructs Setup to be very silent. When a setup is very silent the installation progress window is not displayed.
