My abbreviations ?????
george_lobo
Post by george_lobo » May 15th, ’21, 21:31
Hello, I just bought my registration from FastKeys and I just downloaded the new version 5.03, but I have discovered that "My abbreviations" no longer works as I had configured before, and it no longer works the same, before you could put the abbreviation and the complete phrase , now you can not what happened? or where can I activate it?
before it had the ABBREVIATION AND SUBSTITUTE column
now he doesn't have it
Is it a mistake or has it been permanently removed? To better download the previous version, because I used it a lot.
Jorge Aguero Lobo
Post by Marko » May 15th, ’21, 21:38
You are possibly mixing the Text Expander Phrase file with Auto Complete Wordlist.
Select a Text Expander module and select My Abbreviations Phrase file.
