Having run command listed when doing autocomplete
kuncarlos
Post by kuncarlos » Apr 22nd, ’21, 09:48
I am trying to have Google.com and Google maps when typing Google in autocomplete.
I only can get maps in the same number 1 ( so when doing enter a submenu opens where I can choose maps) and not in number 2. How do I do it to have it in number 2?
My script:
Google:: http://www.google.com
/Maps:: http://www.google.es/maps
Post by Marko » Apr 22nd, ’21, 10:48
Your command works for me, I'm not sure I understand what you mean...
kuncarlos
Post by kuncarlos » Apr 22nd, ’21, 15:39
The command works, yes, but under number one.
the menu opens 1 Google --- https://www.google.com/ and if I do enter it will give me the possibility to choose maps.
I want it to be like this:
When I write google. The menu that pops up to be like:
2 Maps ---- https://www.google.es/maps/
Cheers
Post by Marko » Apr 22nd, ’21, 21:47
To achieve this you need to set two separete commands with similar strings:
Google
GoogleMaps
When you start typing, FastKeys will show both suggestions.
kuncarlos
Post by kuncarlos » Apr 23rd, ’21, 07:25
Thanks Marko.
This was what I wanted.
