Is it perhaps possible to repeat one's last command?
Oblomov
Post by Oblomov » Apr 19th, ’21, 13:14
I was wondering, is it perhaps possible to have some sort of a function, where one would be able to repeat one's last command?
Kind regards,
Post by Marko » Apr 20th, ’21, 20:40
Currently not. How would you repeat the latest command? By using a special key shortcut?
Oblomov
Post by Oblomov » Apr 21st, ’21, 09:35
Marko wrote: Apr 20th, ’21, 20:40 Currently not. How would you repeat the latest command? By using a special key shortcut?
Yep, that would be ideal 😁
Post by Marko » Apr 21st, ’21, 19:12
Possible but not likely to be implemented soon. What would be the typical usage/need?
Oblomov
Post by Oblomov » Apr 21st, ’21, 19:41
Marko wrote: Apr 21st, ’21, 19:12 Possible but not likely to be implemented soon. What would be the typical usage/need?
Gotcha. Off the top of my head, to repeat a macro that didn't go through the first time. I've experienced that selecting something through quick find, doesn't always get executed... this could also apply for e.g. testing out a macro, to try and observe where one e.g., needs to add extra bit of delay...
I'll add more use cases if I can think of some in the future
