Active Windows
vincentt
Post by vincentt » Mar 27th, ’21, 06:01
Is this correct to put the comma to separate the active window like this?
If it's correct, it seems very unstable because sometime it doesn't work.
Thank you.
Post by Marko » Mar 27th, ’21, 20:14
Correct. You may use Window Information Tool to find the correct window names.
For Chrome I recommend
ahk_class Chrome_WidgetWin_1
vincentt
Post by vincentt » Mar 28th, ’21, 02:21
thank you marko!
