how to trigger start menu with command
clideckble
Post by clideckble » Mar 24th, ’21, 02:11
Hello
I want to make a shortcut with some customize code process then trigger the fastkeys start menu.
Does there have some command that can do this, but not by setting the shortcut in preference.
Thanks for help
Post by Tom » Mar 24th, ’21, 12:48
You can simulate pressing the Start menu shortcut as discussed here:
viewtopic.php?t=1330
