FastKeys key remap
izeppelin
Post by izeppelin » Mar 14th, ’21, 22:12
I've been using FK for about a month now and I've just realized that there are some unwanted key remaps. I've turned off ALL default macros / gestures / shortcuts 'case I want full control of it.
In particular it remaped my Ctrl + 1 to Ctrl + C. I can't seem to find why and how is it doing that. However, if I pause FK it works properly.
Two q's:
1. How do I turn off that one and revert Ctrl +1 to default?
2. Is there a way to COMPLETELY turn off all defaults? Another e.g. is the left hand scroll + wheel to turn up & down the volumen.
Post by Marko » Mar 14th, ’21, 22:57
See Preferences/General/Shortcuts and remove the shortcuts. For a volumen control, go to Preferences/Functions and disable it.
izeppelin
Post by izeppelin » Mar 15th, ’21, 03:44
I feel very dumb now and had not thought that FK would also use shortucts to create shortcuts haha. So meta!
Thanks a ton Marko!! :D
Marko wrote: Mar 14th, ’21, 22:57 See Preferences/General/Shortcuts and remove the shortcuts. For a volumen control, go to Preferences/Functions and disable it.
