[Problem] Unexpected shift hold for all autocompletes
ashkan111111
Post by ashkan111111 » Dec 17th, ’20, 17:12
When I run any autocomplete script, the shift is held permanently in way that I have to exit the fastkey and run that again.
As an example, to autocomplete the "covid" to "COVID-19 " the output would be: "COVID_!(".
I reinstalled the FastKey multiple times but it will always show up with my current set of scripts.
Please guide which script is making this happen or should I change settings.
Post by Marko » Dec 17th, ’20, 17:46
This is strange. Could you try resetting the Preferences to defaults?
You can also contact us on our support mail for more detailed help.
