ctrl+c pop up box
gholiday1
Post by gholiday1 » Dec 8th, ’20, 21:25
Total newbie here. Just loaded up fastkeys yesterday. Now when I hit ctrl+c it does NOT copy text as it normally would. Instead, I get a pop-up box. How do I change this keyboard shortcut to something else. I really need my ctrl+c to copy as it did before.
Thanks for any help!
Gail
Post by Tom » Dec 8th, ’20, 21:52
Check your Preferences - see if you have set any of the shortcuts to Ctrl + C.
gholiday1
Post by gholiday1 » Dec 9th, ’20, 00:31
Ok so I'm dumb! The pop up is being generated by another program, NOT by Fastkeys :roll:
