Clipboard Manager "Add to Auto Complete"
GalainDeNo
Post by GalainDeNo » Nov 27th, ’20, 09:08
I tested Fastkeys' Clipboard Manager and I am wondering, if "Add to Auto Complete" would be the benefit for preferring Fastkeys over Ditto.
I noticed that a copied Phrase is multiple times in the Auto Complete list, so I wanted to chek, how the copied data ist stored, but i can´t find an wordlist or phrase file anywhere.
Where can I see, what Faskeys Clipboard Manager stored for Auto Complete, and customize this?
Post by Marko » Nov 28th, ’20, 18:56
Thanks, there is a small bug introduced with one of the last updates. We will resolve it in the next release.
GalainDeNo
Post by GalainDeNo » Nov 29th, ’20, 05:44
Thanks for the info.
But anyway, is there a way to edit this specific list of items, that are added from the clipboard?
Post by Marko » Nov 29th, ’20, 12:26
No, if Add to Auto Complete option is enabled, the clipboard items are automatically added to the regular Auto Complete.
GalainDeNo
Post by GalainDeNo » Nov 29th, ’20, 13:45
OK, thank you for support!
