Stop Alt from bringing up program menu accelerator
daddy_dizaz
Post by daddy_dizaz » Nov 3rd, ’20, 17:40
I am wondering if Fastkeys can replicate a problem which has been solved in AHK which is when Alt is pressed in some programs the menu UI is highlighted and allows the user to navigate it through keys. This is a problem for me in some programs where this menu takes a while to load and delays it from performing the next tab, when I am trying to do Alt tab.
There is an equivalent AHK script created here:
https://github.com/TaranVH/2nd-keyboard ... SABLER.ahk
But I cannot work out how to use this with Fastkeys?
Any help would be much appreciated.
Thanks
Post by Tom » Nov 3rd, ’20, 18:04
The actual AHK script code for left Alt key is
~LAlt::
Sendinput {Blind}{sc0E9}
KeyWait, LAlt ; this wasit for the key to be RELEASED. So that it doesn't keep spamming SC0E9 (as seen from an AHK window Key history and script info... window.)
Sendinput {Blind}{sc0EA}
In FastKeys:
Shortcut: ~LAlt (double click on the shortcut field to enter)
Type: Command
Command:
