Insert text using a number
breta999
Post by breta999 » Oct 28th, ’20, 21:13
Hello
I want to ask if you can use the number at the beginning of the item to insert text for the text expander and autocomplete section. I searched here on the forum and on youtube but I did not find the answer.
Thank you.
Post by Marko » Oct 28th, ’20, 21:53
Yes, you can select the popup item by pressing one of the number keys.
breta999
Post by breta999 » Oct 29th, ’20, 17:30
Do you need any special settings?
Example Text expander
I will write ,dd (original settings)
a menu of 4 items appears
I want to insert a third item
I type 3 (num keyboard) result ,dd3 and the menu disappears
I write 3 (keyboard text) result ,dd3 and the menu does not disappear
Post by Marko » Oct 29th, ’20, 18:46
You need to enable selection keys in Preferences/General/Appearance.
breta999
Post by breta999 » Oct 29th, ’20, 19:57
That's exactly it. thank you very much
