Formatted text change default settings
Florian
Post by Florian » Oct 22nd, ’20, 18:59
The default font for rich txt is Arial 9pt, is there a way to change this globally?
I want it to be Calibri 11pt
Also is there a way to tell fastkeys to expand to the target document's format so that it automatically takes the font of the target "environment"?
Thanks
Post by Marko » Oct 22nd, ’20, 20:37
Actually yes - open Settings.ini file with any text editor and change the following settings:
RTFont=Arial
RTFSize=9
The answer to your second question is no, not in Rich Text mode.
theprofessionalguru
Post by theprofessionalguru » Jun 1st, ’22, 10:14
Hello Marko,
There is no Settings.ini file in my FastKeys folder. Am I missing something?
Post by Marko » Jun 1st, ’22, 10:31
Sorry, the settings.ini file is located in AppData/Roaming/FastKeys folder.
theprofessionalguru
Post by theprofessionalguru » Jun 6th, ’22, 21:59
I can't see any such folders in my FastKeys folder...
