Switching Desktop
Humphries
Post by Humphries » Oct 22nd, ’20, 14:45
Hello, am a completely newbie here...
I am from StrokePlus.net. I am planning to moving to FastKeys due to lack of support in StrokePlus
I am wondering how to set the following using the mouse gesture. I was using strokeplus and it was performing well although with some errors
1. Open Windows explore
2. Opening Notepad
3. Control Panel
4. calculator
5. Switching between virutal Desktop (Win+Alt+Left or Right)
6. Running a program on mouse gestures.
:D :?:
and many many more. I am rellying on the mouse gesteure more than keyboard so most of the funciton I have to bind them to the mouse gestures.
Post by Marko » Oct 22nd, ’20, 20:44
Hi and welcome to the forum.
Many of the mentioned commands are available in the Library. Select a Gesture mode, New button and then select Library button.
To run a program, set Type: Run and click Open button to select a file.
There are many examples already provided in the software - check them out, they are self explanatory. ;)
