Italics in text expander
tpha@plen.ku.dk
Post by tpha@plen.ku.dk » Oct 1st, ’20, 11:47
a couple of years ago i got this solution to make text italic in Text Expander:
Post by Marko » Mon Jul 31, 2017 3:09 pm
- create Text Expander module
- press "New" to create a new item
- set String to "bv"
- set Type to "Send"
- set Substitute to "^iB. vulgaris^i"
- press OK and then Save.
> However, that does not seem to work any longer? i only get the text itself "^iB. vulgaris^i" into the document....
> Alternatively, i can do it in html with the <i> </i> before and after the text to be italizised - the text is then italizised as wanted, but the italics are not turned off after my text which is what i want; thus, the </i> is not interpreted ?.
If I then add a letter after the </i>, e.g. "<i>text</i> L" , and the italics are turned of and the "L" i non-italizised as wanted (except i dont want an L after my text). I thought that i could then remove the "L" by "delete ending char" - but then the "L" is not deleted...
Can you help me with this small puzzle? Thanks in advance!
Post by Marko » Oct 1st, ’20, 14:41
You just need to enable special characters in Preferences/Text Expander.
tpha@plen.ku.dk
Post by tpha@plen.ku.dk » Oct 2nd, ’20, 07:07
Many thanks ! Thure :D
