Oblomov
Post
by Oblomov » Jul 26th, ’20, 18:09
I have a batch called 'Iris delayed restart.bat', which contains:
taskkill /f /im Iris.exe
TIMEOUT /T 10
start "" "C:\Users\Dave\AppData\Local\Iris\Iris.exe"
Which I have inside of the following FK command:
Run, C:\Users\Dave\Dropbox\Iris delayed restart.bat,, Hide
However, whenever I execute the batch manually, it respects the timeout part, which the FK command for some reason doesn't... perhaps I've made a mistake somewhere?
Kind regards
Oblomov
Post
by Oblomov » Aug 5th, ’20, 12:38
It is as though it more or less only works when you wait for a bit, before using the command again, however other times, even after waiting for 5+ minutes, it still doesn't respect the timeout... very strange and perhaps also quite dispiriting
Oblomov
Post
by Oblomov » Feb 14th, ’21, 17:25
The issue still persists, for other batch files that I have tested this with as well...
Post
by Marko » Feb 14th, ’21, 21:19
Interesting. This works for me (Type: Command):
It opens a Notepad after 3 seconds.
Oblomov
Post
by Oblomov » Feb 15th, ’21, 18:38
Marko wrote: ↑Feb 14th, ’21, 21:19
Just tested this and it worked fine for me as well... strange indeed, I'll post back if I figure out more about this
