run a program - singleinstance only
mecanmeup
Post by mecanmeup » Jul 7th, ’20, 11:54
I have a situation as follows, but not sure how to program it by Fastkeys. Please help. THank you.
(1) assign a shortcut key to open a program
(2) after the shortcut key is pressed,
*) if the program is running, and then it will become the active window
*) if the program is not running, then the program will be running first and then become the active window.
Post by Tom » Jul 7th, ’20, 19:26
This example runs or activates Firefox (Type; Command):
IfWinExist, ahk_class MozillaWindowClass
	WinActivate, ahk_class MozillaWindowClass
else
	Run, firefox
mecanmeup
Post by mecanmeup » Jul 8th, ’20, 08:07
Thanks, it works to me. :D
