Google AutoCorrect Selection
smartshaker
Post by smartshaker » Jun 9th, ’20, 11:28
Hi, I am not able to get the Google Autocorrect shortcut to work.
What are the previous steps that are necessary to make it work?
Post by Tom » Jun 9th, ’20, 16:09
Sorry, what is the Google Autocorrect shortcut and how is this related to FastKeys?
smartshaker
Post by smartshaker » Jun 9th, ’20, 16:50
Had problems uploading photo, but see link https://imgur.com/a/AXqQoar
Post by Tom » Jun 9th, ’20, 21:14
Sorry, no idea what you are trying to do...
Oblomov
Post by Oblomov » Jul 20th, ’21, 15:18
Tom wrote: Jun 9th, ’20, 21:14 Sorry, no idea what you are trying to do...
The 'smart' part in that fella's username, definitely doesn't live up to much, if anything at all. That much I'm certain of.
Anyway, I've stumbled into this issue myself today:
This script can be found inside of FK's library (Google AutoCorrect Selection).
I've tried testing it with e.g. 'selectrion' but nothing so far... as in the script, if I'm not mistaken, according to its function, would rename 'selectrion', to its proper, 'selection', once the prior would be selected.
Post by Tom » Jul 23rd, ’21, 17:30
Mentioned script no longer works with Google therefore we have removed it from the Library.
Please see here for possible alternatives: https://www.autohotkey.com/boards/viewtopic.php?t=67469
Oblomov
Post by Oblomov » Jul 23rd, ’21, 17:51
Tom wrote: Jul 23rd, ’21, 17:30 Mentioned script no longer works with Google therefore we have removed it from the Library.
