pasting to excel changes . to , points to comma
Mr.Aky
Post by Mr.Aky » May 22nd, ’20, 06:19
Thank you for your support,
I'im investing a bug (or something I do not know) of a more complex macro.
Do you know why
When copy nome.cognome@test.it and put the clipboard value into User_1
When I paste if I use
Clipboard:=User_1
Sendinput, %Clipboard%
becomes nome,cognome@test,it (with commas)
while if I use
Clipboard:=User_1
Send ^v
it pastes correctly nome.cognome@test.it
Is it a (language) problem of my excel ?
Antopath
Post by Antopath » Dec 11th, ’20, 10:48
Hi all !!
Has anybody ever noticed the fault translation/interpretation of commas and periods with Word or Excel ?
The FastKeys phrase:
AAAAAAAAA, BBBBBBBBBB, CCCCCCCCCCC. CCCCCCCCCCC.
is correctly expanded in Word, whereas in Excel becomes:
AAAAAAAAA, BBBBBBBBBB, CCCCCCCCCCC, CCCCCCCCCCC,
Excel translates periods always as commas ...... Do you think that these characters need to be highlighted somehow in FastKeys to be correctly interpreted?
Thanks !!!!!!!!!
Post by Marko » Dec 12th, ’20, 09:06
This is related to Windows region settings. Try to add a ' prefix to define a text formatted cell:
'AAAAAAAAA, BBBBBBBBBB, CCCCCCCCCCC. CCCCCCCCCCC.
Or, as suggested above, use the clipboard method (Type: Command):
clipboard:="'AAAAAAAAA, BBBBBBBBBB, CCCCCCCCCCC. CCCCCCCCCCC."
send ^v
