Toggling process, rather than window
Oblomov
Post by Oblomov » Mar 24th, ’20, 15:44
Is it possible to toggle the process, rather than window? Photoshop for example, has window name based on file name
I don't suppose it would go something like this?
If WinExist("Photoshop.exe")
	WinActivate
Else
	WinMinimize
Wagoner
Post by Wagoner » Mar 25th, ’20, 13:57
Did you try looking for the files manually, Oblomov?
Post by Tom » Mar 25th, ’20, 18:03
There are several possibilities. I suggest you study the following AutoHotkey commands:
https://www.autohotkey.com/docs/commands/WinExist.htm
https://www.autohotkey.com/docs/misc/WinTitle.htm
Oblomov
Post by Oblomov » Mar 25th, ’20, 18:20
Tom wrote: Mar 25th, ’20, 18:03 There are several possibilities. I suggest you study the following AutoHotkey commands:
This worked for me
if WinExist("ahk_exe Photoshop.exe")
    WinActivate, ahk_exe Photoshop.exe
else ;needs to be reworked
    WinMinimize, A
Not really sure how to get it to minimize once toggled, however 🤔
https://www.autohotkey.com/docs/command ... nimize.htm
Doesn't seem to be of much help
