Can't get a program to recognize an FK command
Oblomov
Post by Oblomov » Feb 28th, ’20, 13:57
I'm having a bit of trouble making
Send, ^{LShift down}!{F1}{LShift up}
Work with VLC, i.e. making the above code work with a command, that would trigger a function within VLC (very short backwards jump). It works just fine when set to Ctrl + Alt + Left inside of VLC and inside of FK with:
Send, {LControl down}!{Left}{LControl up}
However, not with the first command.
Things I’ve tried:
• Clearing up the command a bit ➔
Send, ^!{LShift}{F1}
• Removing L from Shift ➔
Send, ^!{Shift}{F1}
• Restarting VLC
• Testing the hotkey manually, which works just fine, i.e. pressing the keys manually on the keyboard
It's as though VLC doesn't recognize this particular command from FK, for some reason. Despite working just fine, manually
Post by Marko » Feb 28th, ’20, 14:03
To simulate Ctrl+Alt+Shift+F1:
Type: Command
Send, ^!+F1
See Special characters in
https://fastkeysautomation.com/documentation/Send.html
Oblomov
Post by Oblomov » Feb 28th, ’20, 14:09
Marko wrote: Feb 28th, ’20, 14:03 To simulate Ctrl+Alt+Shift+F1:
Type: Command
Send, ^!+F1
Didn't consider that, thanks!
However it still seems to not work 😞
