How to set the same shortcut (e.g. #s) to send one command when single pressing, and another when pressed twice?
cadudesun
Post by cadudesun » Feb 21st, ’20, 13:19
I'd appreciate your assistance.
The script below works properly when it is run as a native AHK script, allowing to set the same shortcut (e.g. #s) to send one command when single pressing, and another when pressed twice.
I tried to implement this script into Fastkeys as a shortcut and a start menu item, being unsuccessful with my implementation in both cases.
How can I run such a script from Fastkeys?
Thank you!
Carlos
#MaxThreadsPerHotkey, 2
KeyPress := 0, running := False
#s::
    KeyPress++
    If (running = True) {
        Return
    running := True
    While (A_TimeSinceThisHotkey < 300) {
        If (KeyPress > 1) {
            MsgBox, Two times
            Return
    MsgBox, One time
Return
Post by Marko » Feb 21st, ’20, 17:26
I suggest using Type: Script for scripts like this. You can run it automatically by using a Start menu with "Run on startup" option.
