Mix HTML commands and keystrokes
CableGuy
Post by CableGuy » Nov 15th, ’19, 16:11
I want to send key strokes with some HTML strings (for a horizontal rule)
or
I want to send HTML with a TAB string to navigate entry boxes on a form
Cheers
Post by Tom » Nov 15th, ’19, 19:04
Try using Non formatted text and "Insert Another Command" macro to insert previously defined HTML formatted phrase.
CableGuy
Post by CableGuy » Nov 19th, ’19, 12:08
Sorry TOM I've tried my best to add the <HR> command into the Macro Command but it doesn't understand it, of course.
Am I missing something, can you tell me how to inject HTML into a No Formatting Send?
Many thanks, I need unformatted so that I can tab through input windows on a form.
Alternatively, I could find a way to send a {TAB} command in the midst of a HTML.
Post by Marko » Nov 19th, ’19, 16:27
As mentioned by Tom:
- create a Html formatted phrase in any module
- create another phrase - Non formatted
- use Insert another command macro (More/Macros...) to insert the previously created html phrase
CableGuy
Post by CableGuy » Nov 19th, ’19, 17:18
Fantatsic it worked - I tried this and failed earlier. I think I know why...
Can I hide my HTML Items for the Macro? They contain nothing more than components to achieve a result.
I have an extensive and particularly welll formatted start menu/board (Ask Marko lol)
Cheers,
Chris
CableGuy
Post by CableGuy » Nov 20th, ’19, 08:58
OK I added it to a second menu that has no shortcut key access so it won't get called up.
I tried to untick it, but this disables it from being called by a macro.
Maybe that could be an option, to allow macros to call an unticked item?
