Selecting a portion of text (within Notepad)
Oblomov
Post by Oblomov » Nov 13th, ’19, 21:32
I very frequently use Notepad to copy/select things and the like, however, I was wondering. Could it perhaps be possible to select a portion of text, that is between 2 enters?
For example this, has "Word Wrap"
So it's basically:
text text text text text text text text text text text text text text text text text
Over time, it gets rather tedious selecting something like that with a mouse, each and every time. So it could be really cool if you could just arrow your way to the portion, and then just press a hotkey that would select the portion you've navigated to
Post by Marko » Nov 14th, ’19, 17:58
Why not using standard Windows shortcuts? For example, in Word, you can press Ctrl+Shift+Down/Up to select a paragraph. There are no paragraphs in Notepad but you can press Shift+Down/Up to select the text lines.
Oblomov
Post by Oblomov » Nov 14th, ’19, 18:47
Marko wrote: Nov 14th, ’19, 17:58 Why not using standard Windows shortcuts? For example, in Word, you can press Ctrl+Shift+Down/Up to select a paragraph. There are no paragraphs in Notepad but you can press Shift+Down/Up to select the text lines.
The Shift+Down/Up does indeed do the job, although it always selects an enter below, together with it. Which can be fixed with one Shift+Down/Up
But yeah, working with many "paragraphs" or rather clusters, of more than 2-3 lines within Notepad, does however kinda rob one of time, especially in the long-term. I would say
Oblomov
Post by Oblomov » Nov 28th, ’19, 19:29
Seems that using "Send, ^{LShift down}{Left}{LShift up}" would be more optimal, upon repeated use. However, I can't quite seem to get it working, as it only ends up selecting one letter, instead of a word 🤔
