Text Expander problem
AndaK
Post by AndaK » Nov 1st, ’19, 20:25
I use a text file with following stats:
string: rd1
description: random quotes
type: send
=================actual quotes====================
quote 1
/quote 2
/quote 3
/quote 4
/quote 5
options: trigger immediately ; delete ending char
window: AdiIRC
It is not working like intended and I can't get it to work properly. I can type 'rd1' and the popup window comes up. I click
(or select with up or down button and there seems to happen something but it immediately vanishes before anything
is printed in chat. In notepad it prints a test with the / in front of text so it 'seems' to work.
thank you :)
Anda
Post by Tom » Nov 2nd, ’19, 19:45
Hm, could you try disabling Auto Complete module and see if it helps?
