Shortcut for sorting words and numbers list
gbop515
Post by gbop515 » Oct 29th, ’19, 04:26
Hi...
I'd like to add shortcut - to sort list which contains words and numbers.
For example - list contains random alphanumeric order below:
nimble
quick
9 velocious
accelerated
12. hasty
rapid
swift
active
Into alphanumeric ascending order output:
12. hasty
9 velocious
accelerated
active
nimble
quick
rapid
swift
Into alphanumeric descending order output:
swift
rapid
quick
nimble
active
accelerated
9 velocious
12. hasty
Is it possible to achieve sorting with FastKeys?
Thank you so much!
gbop515
Post by gbop515 » Oct 29th, ’19, 04:40
There is built-in shortuct - Change Caps Text Utility: Ctrl + Capslock. I love it so much.
It'd be nice if I can add "Sort List" feature in there.
Post by Marko » Oct 29th, ’19, 08:09
The following command sorts the selected lines of text (Type: Command).
send, ^c
sleep 100
sort, clipboard
send, ^v
To sort in reverse order use:
sort, clipboard, R
More info: https://www.autohotkey.com/docs/commands/Sort.htm
