Here's an example picture to accurately describe what I want to do.
http://imgur.com/ytSopXv
Every time I put the {{}} around words, it makes them blank and I have to type in the answer. However, bolding the text in between the brackets, makes certain words bolded.
I have a shortcut on Fastkeys Setup to paste those brackets around any thing that is selected. Is there anyway to write a script or command that selects the text between the {{}} and then makes it bold via the shortcut Ctrl + B?
