Downside of always using clipboard for Text Expander?
NW5o4vTsxVyAY4AY
Post by NW5o4vTsxVyAY4AY » Sep 28th, ’19, 07:56
is there any downside to always using the "Use clipboard if text length exceeds (char)"-option (Preferences -> Text Expander -> Advanced), even for text that is not long?
Best regards.
Post by Marko » Sep 29th, ’19, 20:15
In general not, some macros (like Pause) may not work though.
NW5o4vTsxVyAY4AY
Post by NW5o4vTsxVyAY4AY » Oct 2nd, ’19, 04:35
Thanks for your response.
(I'm currently using Text Expander only for plain Send commands anyway, so that shouldn't be an issue).
