How can I make this 'remove ALL formatting from clipboard' script toggle-able?
alih1029
Post by alih1029 » Sep 23rd, ’19, 18:03
#SingleInstance
OnClipboardChange:
ToolTip Clipboard data type: %A_EventInfo%
StringReplace, Clipboard, Clipboard,  `r`n,%A_Space%, All
Sleep 1000
ToolTip  ; Turn off the tip.
I'm using the above script with this one below that allows me to AUTO select any highlighted text immediately upon highlighting.
MouseGetPos, xx
TimeButtonDown = %A_TickCount%
; Wait for it to be released
Loop
   Sleep 10
   GetKeyState, LButtonState, LButton, P
   if LButtonState = U  ; Button has been released.
      If WinActive("Crimson Editor") and (xx < 25) ; Single Click in the Selection Area of CE
         Send, ^c
      break
   elapsed = %A_TickCount%
   elapsed -= %TimeButtonDown%
   if elapsed > 200  ; Button was held down too long, so assume it's not a double-click.
      MouseGetPos x0, y0            ; save start mouse position
      Loop
     Sleep 20                    ; yield time to others
     GetKeyState keystate, LButton
     IfEqual keystate, U, {
       MouseGetPos x, y          ; position when button released
       break
   if (x-x0 > 5 or x-x0 < -5 or y-y0 > 5 or y-y0 < -5)
   {                             ; mouse has moved
      clip0 := ClipBoardAll      ; save old clipboard
      ;ClipBoard =
      Send ^c                    ; selection -> clipboard
      ClipWait 1, 1              ; restore clipboard if no data
      IfEqual ClipBoard,, SetEnv ClipBoard, %clip0%
; Otherwise, button was released quickly enough.  Wait to see if it's a double-click:
TimeButtonUp = %A_TickCount%
Loop
   Sleep 10
   if LButtonState = D  ; Button has been pressed down again.
      break
   elapsed -= %TimeButtonUp%
   if elapsed > 350  ; No click has occurred within the allowed time, so assume it's not a double-click.
;Button pressed down again, it's at least a double-click
TimeButtonUp2 = %A_TickCount%
Loop
   Sleep 10
   GetKeyState, LButtonState2, LButton, P
   if LButtonState2 = U  ; Button has been released a 2nd time, let's see if it's a tripple-click.
      break
;Button released a 2nd time
TimeButtonUp3 = %A_TickCount%
Loop
   Sleep 10
   GetKeyState, LButtonState3, LButton, P
   if LButtonState3 = D  ; Button has been pressed down a 3rd time.
      break
   if elapsed > 350  ; No click has occurred within the allowed time, so assume it's not a tripple-click.
   {  ;Double-click
      Send, ^c
;Tripple-click:
   Sleep, 100
   Send, ^c
