rtf not working within any browser or outlook
egsys
Post by egsys » Sep 4th, ’19, 02:19
Just installed trial version 4.21. No matter what I do I cannot get rtf to work in any browser or outlook. I read about this in the forum and have tried some delays but to no avail. When you type in a code abbreviation you see the cursor back up and wipe it out and try to do something but nothing happens. Reg. text and html work fine. It is only happening with RTF. Really need to get this to work for my client in order to purchase it.
Post by Tom » Sep 4th, ’19, 10:58
Unfortunately not all on-line rich text editors follow the same standards. Most of them accept Html perfectly fine while Rich text may be an issue with many. To overcome this try the following alternatives:
- use non-formatted text with "Insert Image" macro (More/Macros...)
- prepare rtf file in another application and use "File Contents" macro (select saved rtf file)
- use Html formatted text.
