Suggest me a quick way to toggle between....
Admirer
Post by Admirer » Aug 28th, ’19, 06:53
Suggest me a quick way to toggle between two open windows (programmes) using Fastkeys! :roll:
Post by Marko » Aug 28th, ’19, 08:19
if not WinActive("App1")
	WinActivate App1
else if not WinActive("App2")
	WinActivate App2
Admirer
Post by Admirer » Aug 29th, ’19, 02:04
:D please explain me a little about this code!
Which key i have to use to toggle between two programs? Windows key?
I wish it should work to toggle the top 2 programs out of many which are open.
Thanks.
Steve Clark
Post by Steve Clark » Sep 3rd, ’19, 23:34
If you're using a windows machine...
Try holding down the ALT key and press TAB to cycle through open windows (Programs) :D
Steve
