What's new in FastKeys 4.11:
August 7, 2018
Release notes:
- Fully customizable individual Start Menu entries (colors, font, size etc.)
- Additional Start Menu appearance options,
- Multiple monitor support improved,
- Description available in Radio control type selections,
- Language translation updates,
- Various improvements and bug fixes.
Please let us know how you like the new features or if you have any comments.
Download FastKeys HERE!
FastKeys 4.11 Released
Thank you!
Edit: Tested the changes here, and everything is working fine. But I couldn't find a way to change the Menu icon, if there is a submenu item. For example, I have a Scripts Menu, with multiple submenu itens inside. Is it possible to set an icon for that Scripts menus?
Thanks for your testing!
You are right, in the current design it is not possible to set an icon for a parent menu.
Marko, I can't tell you how much I love this app. Improving multiple monitor support, specifically, preventing input windows from disappearing off the edge of the screen is a huge, huge thing for my workflow. Input window positioning is great. Thank you so much!
