FastKeys 3.18 Released
Post by Marko » Mar 8th, ’17, 23:30
What's new in FastKeys 3.18:
March 8, 2017
Release notes:
- Enabled sorting of Phrase files and Wordlists,
- New Auto Complete option - Send raw text,
- 'Display suggestions as you type' option is no longer dependent Auto Complete module being active,
Download FastKeys HERE!
gustms
Post by gustms » Mar 11th, ’17, 21:35
Thank you!
thinman
Post by thinman » Mar 12th, ’17, 17:20
Thanks for a great update, very stable and mature product!
Joker
Post by Joker » Mar 14th, ’17, 18:59
Hello! How can I solve this issue https://vitaly.tinytake.com/sf/MTQxNjYxMF81MDg1ODQw? I get this error after the last update. Thank you in advance.
Post by Marko » Mar 15th, ’17, 07:10
One of your commands contains a syntax error. Try disabling recently added commands to see where the issue is. You can also send us your settings.fdb file and we will help.
Pro
Post by Pro » Apr 12th, ’17, 18:25
Works great now!
Had to delete the settings.fdb or reinstall the program, because I had some errors from 4 Versions ago. But now it works great!
Also I like the preinstalled examples! :)
Basically if someone had errors, reinstall the whole program!
