FastKeys 3.03 Released
Post by Marko » Aug 29th, ’15, 14:37
What's new in FastKeys 3.03:
August 29, 2015
A new macro has been introduced: Insert Another Command. This is a very powerful feature which allows linking and nesting phrases or commands. Here are some typical examples:
- re-use the same text - create an email signature to be used in other phrases,
- prepare advanced text automation - insert multiple phrase selections to be triggered interactively - see a new "Advanced Mail Example".
And the best of all, you can link commands between all modules.
A new Windows Information Utility (under Tools menu) allows user to quickly retrieve more detailed information about open windows and controls. This information can be used in custom scripts or window context sensitive actions (name, class).
- New Macro: Insert Another Command - reuse the same text or actions
- Windows Information Utility - get detailed information about open windows and controls
Download FastKeys HERE!
gustms
Post by gustms » Aug 29th, ’15, 14:39
Thank you, Marko!
Gryzor
Post by Gryzor » Aug 29th, ’15, 17:46
Not for me, but really nice seeing this progress!!!
ChrisFK
Post by ChrisFK » Aug 30th, ’15, 13:10
I already wished such a thing like macros would exist.
Thanks for realizing it :-)
ChrisFK
Post by ChrisFK » Aug 30th, ’15, 13:16
Could you please provide a download for the portable version.
(Installer for the portable version says it installs v302)
thanks
Post by Marko » Aug 30th, ’15, 21:43
thanks, installer corrected.
ChrisFK
Post by ChrisFK » Aug 31st, ’15, 08:19
Hi
Thanks for the installer - I gave version 303 a try and encountered a major problem.
The left mouse button click seems to get absorbed by fastkey -> the effect is: I can't left click anywhere :-(
So I downgraded to version 302 (which I never used before) an noticed that the problem still was the same -> so I downgraded to version 301 and everything worked like before.
So a change from version 301 to 302 (that still exists in v303) is causing problems on my system. Hope you can help.
Thanks
Chris
Post by Marko » Aug 31st, ’15, 08:49
must be related to your specific settings or commands. Could you please contact me on our support mail and we can check what is the issue?
ChrisFK
Post by ChrisFK » Dec 12th, ’16, 03:56
Marko wrote:
must be related to your specific settings or commands. Could you please contact me on our support mail and we can check what is the issue?"
you got mail" thanks
