FastKeys 3.08 Released
Post by Marko » Feb 27th, ’16, 15:06
What's new in FastKeys 3.08:
February 27, 2016
"Display suggestions as you type" feature behavior is now improved when in conflict with regular text expanding. Key delay setting is useful in some applications which cannot handle fast keystrokes. One example is Windows 10 Mail - try setting key delay to 20ms to avoid issues. You can restrict a delay to only selected applications/windows - for example set it to "ahk_class ApplicationFrameWindow" to only have a delay in Mail.
- "Display suggestions as you type" behavior improved,
- Advanced Text Expander preferences - Key Delay setting
- User preferences updated,
Download FastKeys HERE!
gustms
Post by gustms » Feb 29th, ’16, 14:15
Thank you, Marko!
JGM22
Post by JGM22 » Feb 29th, ’16, 15:06
Marko, thank you for the updates, much appreciated as always...JGM
hpenner
Post by hpenner » Mar 1st, ’16, 10:51
After updating i get this error:
ERROR. Some Commands were stopped.
Please check latest edited commands and correct possible duplicate funktions.
I did not edit any commands. What is the problem?
Sry but i am new at fastkeys?
Post by Marko » Mar 1st, ’16, 16:05
Could you disable your added commands one by one to see which one is causing the trouble?
If you wish you can also send us your Settings.fdb file for inspection.
fastkeys.info at gmail.com
hpenner
Post by hpenner » Mar 3rd, ’16, 13:53
I swiched back to 3.07. Luckely i found the install file in my download-folder. Can i send you my setting file anyway or are there other settings after updating?
Post by Marko » Mar 3rd, ’16, 18:12
Yes, please send your settings file.
