Example of text expand for email?
ascharf
Post by ascharf » Jun 14th, ’16, 16:01
Hi
Can you please give me an example of making a text expand shortcut to type an email address?
Thanks.
Alan
Post by Tom » Jun 14th, ’16, 23:02
Hi Alan, welcome to the forum.
Depends on what you want to do. If you just want to expand the email adress, create a Text Expander item, Type: Send and set Substitute to youremail @adress.com.
You can also automate the process. This is one of the scripts from the Library. Set Type: Command and paste the following to command field (adapt with your data):
to:="to@email.address"
cc:="cc@email.address,cc@email.address"
bcc:=" "
subject:="Hello"
body:="Best regards,%0A%0AJohn"
Run mailto:%To%?cc=%cc%&bcc=%bcc%&subject=%Subject%&body=%body%
