I do some freelance editing and use both MS Word's Review feature and also inline editing...and here's where I'm having some difficulty getting FK to do something.
An example: Now is the time [Delete "time" replace with "clock"] -- it's a simple Send shortcut: ^{vk43}{Right}{Space}[Delete "^{vk56}" replace with "%INPUT_Replacement%"]
However, what I want is [Delete "time" replace with "clock"] to be red. (everything between and including the brackets in red). I've tried using Rich Text, but it sends everything. Any ideas? I have quite a few shortcuts like this.
In a related question, I'd like to be able to separate my editing shortcuts from other shortcuts via a folder system or similar:
Editing: shortcut1, shortcut2, shortcut3...
Writing: shortcut4, shortcut5, shortcut6...
other topics/folders.
I looked at other text expansion applications, such as PhraseExpress and PhraseExpander, but they're expensive. However, they do have some organization for phrases.
Fiction editing help
FastKeys simulates keystrokes just like you would press keys on a keyboard.
There are shortcuts for bold, italic or underline formats and you can send it like this:
For other formatting you would have to use more complex commands (Type=Command). For example in Word one way would be to use
I hope you get the idea and you can adapt it to your needs. It would also be possible to make a macro to simulate opening Word font color dialogs etc.
^bThis is bold text.^b
SendMode, Event
InputBox, Replacement
Send Normal text.
Word := ComObjActive("Word.Application")
Word.Selection.Font.Color := 0xFF
Send Text in red.
Word.Selection.Font.Color := -0x1000000
Send %Replacement%
Word:=""
Re your other question: you can use tabs to organize your shortcuts. Right-click on a tab and select New tab. Then you can copy and paste from one tab to another.
