Send an URL by Mail
weberwa
Post by weberwa » Feb 24th, ’15, 10:29
Being a beginner in such things:
What would be a possible Commandline for
"Pick up the current URL (in Chrome) and prepare an email containing that URL in the email body (for example in Lotus Notes)"?
I know: There is/was an extension for that in Chrome, but this does not work anymore (in Windows) for whatever reason.
Thank you for every suggestion -
Walter
Post by Marko » Feb 24th, ’15, 12:04
Hi Walter, the script below first selects an adress field in a browser (F6), copies it into clipboard and then runs a Windows Mailto command with specified parameters. It works for me, you may have to play a bit with a Sleep commands in case you see the issues on your computer. You can of course change all the mail fields (to, cc, subject, body...)
Send, {F6}  ;select adress field
Sleep 100
Send ^c		;copy adress to clipboard
Sleep 300	;change if not reliable
to:="to@email.address"
cc:=" "
bcc:=" "
subject:="Link"
body:=Clipboard "%0A%0ABest regards,%0A%0AJohn"
Run mailto:%To%?cc=%cc%&bcc=%bcc%&subject=%Subject%&body=%body%
weberwa
Post by weberwa » Feb 24th, ’15, 13:27
Hi Marko
Thank you very much, works!
I had to appoint "mailto:" to Lotus Notes first, then it worked.
Excellent support, again!
Walter
