Hi Marko/Tom,
I have been using FastKeys for a few weeks now both at home and at work and it is fantastic. Something that crossed my mind as I was building out my phrase files. Would it be possible to make select tabs or phrase files for the text expander optional in the auto complete settings? Perhaps some sort of on/off toggle? In my particular case I have a phrase file for words that I want to auto complete but I also have a phrase file for thousands of 4 digit numbers that I want to trigger immediately and not offer auto complete suggestions. Thanks for your time.
Auto Complete Optional For Select Tabs/Phrase Files
I'm not sure I understand what you mean. You can enable/disable one or multiple selected item(s) by checking the checkboxes or from the context menu (Enable/Disable).
Auto Complete - use Wordlists of words to be suggested.
Text Expander - use Phrase Files of phrases to be automatically expanded.
Hi Tom,
Thanks for the reply. I am an idiot. I figured this out on my own I just placed one phrase file under the auto complete module and another under the text expander and this satisfies my requirements. I would delete this post if possible. Please ignore.
