Folders for Text Expander
jmccun3RPfk
Post by jmccun3RPfk » Feb 4th, ’18, 16:55
Maybe most users don't need this feature.
I have DOZENS of text expand hot keys. It would help very much if they could be sorted into folders.
A bit of old freeware I used for years was set up this way (called Auspex--in most other respects FastKeys is dramatically better than that freeware.)
Post by Marko » Feb 4th, ’18, 21:55
In FastKeys you can organize items into tabs. Right-click on any tab to open a tab menu or select Insert/New Tab to add a new tab.
Alternatively you can organize simple text expanders into Phrase files. :)
