TextExpander - Folders / Labels / Categories
singularity
Post by singularity » Oct 28th, ’17, 01:46
It would be helpful if the textexpander supports sub-folders / labels or categories to organize phrases. For eg: like Emails, Websites, Work, Snippets. This would help us to find, edit , organize large number of custom phrases like Breevy.
Post by Marko » Oct 28th, ’17, 06:52
Hi and welcome to the forum.
In FastKeys you can organize items into Tabs. Right click on any tab to create a new tab. You can also move items between tabs using Cut and Paste.
In addition you can create Phrase files to contain simple phrases.
singularity
Post by singularity » Oct 28th, ’17, 08:44
Thank you for the warm welcome.
And good to know about tabs feature. Thank you.
How can I create a new phrase file? When I tried by "new" file/phrase file it says file does not exist.
Do I need to create a blank *.fkp file first?
Post by Marko » Oct 28th, ’17, 10:07
No need to create a blank file first, FastKeys will do it for you - Insert/New Empty File.
